Max 30102 df robot
MAX 30102 DF ROBOT Heart Rate & Oximeter Sensor
anyone have this? please
Previous work, similar parts
A google search of the form “fritzing part MAX 30102 DF ROBOT Heart Rate & Oximeter Sensor” turns up several hits (and is the best way to find existing parts), if that doesn’t suit then you need to fill in the template in this group (that you appear to have deleted instead of read and obeyed) that provides a web site with physical dimensions and connection information for the exact part that you want.
I apologize, I am new to this website, and I will recreate it.
I have changed it, can you help me please?
Likely although the DFrobot web site is a more useful site than the chip’s datasheet as we need the connector information for the board not the chip. It may take some time as there is another request before you and I am busy. @RAPTOR7762 may have some time to do this for you if you are lucky.
I can make it later.
Thanks, I’m working on the relay part.
There might be one in their library of parts, but knowing their standards better off creating from scratch
@aisyhfrdla Here
dfr-sen0344_SMD.fzpz (17.2 KB)
dfr-sen0344_THT.fzpz (17.3 KB)
Thank you very much :raising_hands:
