Malformed contour.gm1 file with custom PCB shape
TL;DR 1.05 and 1.06 create duplicate %ADD10C entries in contour.gm1 making it malformed so it doesn’t work with JLCPCB online viewer.
  1. Created a new PCB project
  2. Downloaded the custom PCB star example from Fritzing-Custom-PCB-HowTo/custom_star_pcb.svg at master · duff2013/Fritzing-Custom-PCB-HowTo · GitHub
  3. Used that PCB as a custom board shape
  4. Exported my project as extended Gerber
  5. Uploaded to JLCPCB. The online viewer showed a rectangle not the star
  6. Edited the contour.gm1 file. Saw that there were two different ADD10C command
    %ADD10C,0.005000*%
    %ADD10C,0.008*%
    Also there were duplicate G54D10* commands.
  7. Deleted the line %ADD10C,0.005000*% and one of the duplicate G54D10* lines
  8. Re-uploaded to JLCPCB. The online viewer showed the correct PCB shape, showing the duplicate entry was the problem.
It should have had only one %ADD10C entry in contour.gm1
1.06 on Ubuntu Linux
Star.fzz (2.0 KB)
@sewnbacktogetherwron Your best bet is to post in
As a data point the sketch appears to work correctly for me on Fritzing 1.0.6 on Win10 (here is contour.gm1 displayed by gerbv):
Hi Peter,
Thanks for the follow up! I’d be curious to know if the output you produced from the Windows version includes two ADD10C lines in _countour.gm1?
%ADD10C,0.005000*%
%ADD10C,0.008*%
I tested my malformed star pcb in gerbv and it displayed fine. I also tested in in PCBWay’s online viewer and it displayed fine. It was only in JLCPCB’s online viewer that it appears corrupt due to the duplicate ADD10C lines. So it seems like only some viewers have problems with the duplicate ADD10C lines.
Thanks!
Yes, but that doesn’t appear to bother gerbv (and may be a bug!)
