I literally make at least one new one-off part per week. If I need a 0.650" resistor I pull the svg, move the nodes, put it back in, and 3 min latter bang it’s done. Then I share it to help the community. You have to make the decision to remake and move separate pads for the rest of days, or learn how to make parts.
By the sounds of it this video is all you need.
FZ is not really SMD ready, because it was never intended to be high end, it’s just that people like it so much they are slowly making it better.
I noticed that SMD has different names for similar footprints, so if the footprint doesn’t come up in a search just pull components in PCB view until you see the correct one.
Here is a car EMS using SMD, and also using my DENSO and MPX sensor parts that used to be individual header pins and holes, without silkscreen outlines, from the CORE parts bin.
