Dear all
Please i want the fritzing part of this component
Best Regards
Dear all
Best Regards
Not enough information to do anything useful. We would need a website with the dimensions, and connections for the module.
These are some information about this part:
Features
OK here are a couple of parts that should do what you want. The first part is tht so you can use 1.27mm headers to plug the module in using the inside set of holes (DIO4 and DIO5 will be a little dicey!) The SMD part has pads to solder to the pads on the board. On the SMD the rf (ANT and GND) are not connected as you will probably need to do something special there directly to the module I expect (likely solder the antenna directly in to the hole on the module!)
LoRa-sx1278-module-smd.fzpz (16.0 KB)
LoRa-sx1278-module-tht.fzpz (16.0 KB)
In breadboard it is necessary to start from the pin on the module because the 0.05in pitch confuses the wire connector and it will usually connect to the wrong pin unless you start at the pin on the module.
thank you very much sir
