LoPy 4.0 and BMP 180 Barometric sensor
Hello, I want the LoPy 4.0 and BMP 180 Barometric sensor.
There are Fritzing parts for the BMP180 barometric sensor (a Google search of the form “fritzing part BMP180 module” will find them.) It is unclear what a LoPy 4.0 might be though a data sheet or web site of what you want would be required as nothing comes up in a search for “Fritzing part LoPy 4.0”. This should also be in parts help not parts submit, but that is a minor nit.
Dear Peter! Thank you for reaching out. It seems there might be a small confusion regarding the name of the device I mentioned. Instead of “LoPy4.0,” the correct name is Pycom LoPy4 .
These two parts should do what you want. One is THT (for use with headers) and one is smd to solder to a board (both options appear to be available.)
Pycom-LoPy4-tht.fzpz (36.2 KB)
Pycom-LoPy4-smd.fzpz (36.1 KB)
Dear Peter,
thank you for your help.
—Francilly
