This part should do what you need. Note that it was created from a jpg image as I can’t find a mechanical drawing (nor does this board appear on the Wemos site, making me wonder if it is a Wemos board …) so before ordering boards print out pcb view at 1:1 scale and check the footprint against a real part. Also if you want the mounting holes drilled you need to drag a hole in to your sketch and place it over the mounting holes (which are only in silkscreen.)
