Hello @meliphona and welcome to the forum.
In the interest of keeping things easier readable, could you possibly migrate your text into your post instead of having a rather humongous title?
Also, if you could please link the part you had found already as this may be modifiable?
Your linked module:
Air humidifier atomization drive module is suitable for controlling the ultrasonic micro-hole atomization plate through Arduino
Thanks for answer me, here is the link Grove atomizer v1.0
I have not found a proper description, do you have the board already or a description?
If so, the bottom of the board seems to hint that the connector on the top (V G) is DC in, the connector on the right is marked G V S. I assume V is voltage (DC+) G is ground and S is switch (enable). Can you confirm that V and G are looped through?
I have the board, you’re right V(voltage or VCC), G(Groung) and S(Signal)
Can be used as icon:
Edit:
unused content removed and scaled
Thank you so much, it’s perfect, you really helpped me
@meliphona I can make thi spart for you
An .fzpz file? That would be great, because I was having trouble creating the part in my software.
Yes creating a part is super tough. @meliphona It’s basically like trying to build an object and prevent it from exploding
If you can make this parte for me I will be so grateful
Hi @meliphona Sorry I fell pretty sick for about a week so sorry.
No worries, thanks for try
@meliphona Here’s the part you want
WAVGAT HE-30 AIr Humidifier Atomization Module.fzpz (9.8 KB)
Thank you very much, you helped me a lot ![]()
