Wago 2604-1102 Wire conenctor
Insufficient information to do anything with. You don’t specify how many positions you are interested in (the picture has both 2 position and 3 position and I expect there are more available.) A google search of the form “fritzing part Wago 2604-1102” indicates there are some wago Fritzing parts available but not this particular model.
This is a 2 position connector
This part should do what you want. The holes in pcb are set to 0.052in which appears to be what they are recommending in the data sheet but you may wish to check that against a real part.
Wago-2604-1102.fzpz (4.8 KB)
Thank you Peter!! Your the best!!
