Here is the datasheet.
This part in core parts should do unless you need pcb to be accurate (it is around 10mm rather than 5mm in pcb.) If that won’t do you will need a custom part.
The coil I have has a spacing of 0.2in between both pins, the one on Core Parts has a 0.4in spacing.
