I am looking for the Adafruit 12V Bias Voltage Boost Converter - TPS61040
Datasheet: https://cdn-shop.adafruit.com/product-files/5644/tps61040.pdf
Thank you in advance
Onan
Onan
This part should do what you want. As usual the mounting hole is not drilled by default, if you want a mounting hole drilled you need to drag the pcb/hole part in to the sketch place it over the hole in silkscreen and set the size appropriate.y. If the Adafruit folks wish to add this to their repository feel free to do so I have no objections.
adafruit-TPS61040.fzpz (6.4 KB)
Thanks a lot @vanepp
