Looking for SparkFun Simultaneous RFID Reader - M7E Hecto (WRL-24738)
I’m working on my senior design project and need this part to try and make a PCB for it. If anybody has this part Id love to receive the file, thank you.
https://docs.sparkfun.com/SparkFun_Simultaneous_RFID_Reader_M7E/assets/component_documentation/M7E_HECTO_User_Guide.pdf
Now I’m creating this part. Just to confirm – What are the connectors here
There is a schematic in the Sparkfun docs. There are also Eagle files meaning Eagle2Fritzing would maybe produce a part when I get to it.
OK, I’ll make just the breadboard SVG :slight_smile:
Eagle2Fritzng generally makes a breadboard svg. I’m just about finished my current project and should get to this later today.
Oh, I see. Nvm, just finished breadboard view right before you posted.
182734
OK then assuming e2f produces one it won’t be needed :slight_smile:
This is what your breadboard should look like (from the Eagle files)
SparkFun_Simultaneous_RFID_Reader_M7E_breadboard
the blue background needs to change to red, mostly of interest for pad placement though as I didn’t post process the svg to remove the unwanted pins that are probably present.
and pcb
SparkFun_Simultaneous_RFID_Reader_M7E_pcb
(silkscreen here is white, you need to change it to black to be useful.) Schematic is present but Randy’s extension is a better bet.
This should be the part you want. Please stay tuned for any updates :slight_smile: (part is subjected to issues)
SparkFun Simultaneous RFID Reader - M7E Hecto (WRL-24738).fzpz (38.9 KB)
Don’t see any obvious problems …
Thank you all so very much.
