Looking for MQ-2 Gas Sensor
This is the relevant picture. Thank you all!
@sdjh your topic has been shifted to the parts help category. All part requests topics go there. As well the title of the topic has been changed
Hello, it’s the MQ-2 component.
Check if the connectors are the same
Bye for now. It’s 12 midnight here. @vanepp can you help me reply him if he asks anything?
Hello, it seems to be a similar connector. May I ask a small question? Can the name be changed to MQ - 2?
Can is can.
You have to modify the SVG.
How do I modify it? I don’t quite understand. I’m really sorry.
If he still needs it, I will try my best to answer him.
@sdjh here: MQ-2 breakout.fzpz (48.1 KB)
Open the SVG with a text editor and change this section
    <text
      font-size="60"
      y="162.64647"
      x="355.77576"
      id="label"
      font-family="'Droid Sans'"
      text-anchor="middle"
      fill="#000000">MQ-5</text>
to
    <text
      font-size="60"
      y="162.64647"
      x="355.77576"
      id="label"
      fill="#000000">MQ-2</text>
Save the file.
Then right-click the part → edit
load image for view
then go to metadata and change from
to
file → save as new part
I’m really grateful to you for helping me finish the revision! Thank you so much!
Do you have the libraries for MQ-6 MQ-2 and MQ-135.
I am using these sensors for a project, I have found the MQ- 4 and MQ-7 libraries but I can’t find these sensors libraries(MQ-2, Mq-6 and Mq-135). If anyone is looking for the libraries for MQ-4 and MQ-7, just reply to this message and I will send it to you.
Thank you
