MQ-137 Ammonia (NH₃) Gas Sensor
I have searched for similar Fritzing parts such as MQ-2, MQ-3, MQ-4, MQ-7, and MQ-135, but I could not find a dedicated MQ-137 part.
The MQ-137 is specifically designed for ammonia (NH₃) detection, so it cannot be directly replaced by other MQ-series sensors.
(Please paste the image here — no links, image only)
The image should show:
- Top view of the MQ-137 sensor
- Clearly visible 6 pins
- The typical metal can cylindrical shape of MQ gas sensors
Acceptable images:
- A clear photo of the MQ-137 sensor
- A top-view or pin-layout image from the datasheet
The official manufacturer documentation is available here:
MQ-137 Datasheet (PDF)
TO-5 (6-pin metal can gas sensor)
(Not an SMD package, typically mounted on a PCB or used with a breakout module)
Hardware, mounting screws, etc. (H)
Plug, movable part of a connector pair (P)
Zener diode (Z)
Other – Gas Sensor (Ammonia / NH₃)
