Hi there,
i am looking for a Fritzing library for the MQ-131 Ozone sensor. I’ve found nothing on the internet.
Does anyone here have the library i am looking for?
Thank you in advance
Hi there,
This may do what you want. Note you need to check the pin labels match your board (because I took the pins from the first unit I saw.) If they don’t match there is a good chance you will destroy the module.
MQ-131.fzpz (8.8 KB)
Thank you, that’s the correct part :))
