Hello, i am looking for TFT ILI9225.
This part should do what you want. Note by default the mounting holes are not drilled. If you want mounting holes drilled drag a hole in to the pcb of your sketch and set the size appropriate.y.
2_2in-lcd-ili9225.fzpz (6.1 KB)
Thank you ! i will do !
