Looking for LGA10 5mm part (MAX31328/9)
I was looking for a Fritzing part for the MAX 31329, using a 5mm LGA10 package. So far I have not been successful, using the forum search and Google search. In Fritzing I found an LGA12 package, but this appears to be unfortunately for a 3mm LGA12.
Are there such Fritzing parts and I just have not looked right?
The manual contains the package code (L1055M+2C) as well as the outline code and land pattern.
Edit:
Unrelated to Fritzing but in case someone else looks at 3.3V RTCs, at least the MAX31328 is well covered on Github:
This part should do what you want. Before ordering boards it would be advisable to print the footprint out at 1:1 scale and compare it to a real part to be sure it is correct.
MAX31328.fzpz (5.4 KB)
I always do this, thank you very much.
