Looking for HaLow MM8108-EKH05
MM8108-EKH05
I need help to get fritzing part MM8108-EKH05. Anyone have any source to this part?
Thank you very much.
The official documentation of the part manufacture is linked here: Datasheet
There don’t appear to be clear enough images available to make out the pin labels (and the debug connector has no indication of what the pins are labeled in any of the documentation I have found so far.) so a part is likely to be difficult to make without more information.
forgot to add the example screenshots of the problem! The text here isn’t clear enough to read accurately.
Same here, the text is partly overwritten by the green box and not readable (at least to my old eyes.)
The Datasheet contains a photograph that is high resolution:
PS: That part is quite a beast. Many connectors, different types of connectors, placed all over the board, and no CAD file to extract the positions from.
Probably lots of buses/subnets, too.
I missed that photo, I’ll have another look. Yes it will be fairly complex and I don’t see any dimension information anywhere either but I guess we will see how it goes. Thanks for the pointer to the better image!
This part should do what you want. Note pcb view has been suppressed as not useful and the debugger pins are labeled 1-16 as there is not connection documentation for them.
MM8108-EKH05.fzpz (75.9 KB)
