Hopefully this question hasn’t been asked before (I can’t find mention of it here), but I’m looking for a Fritzing part for DFRobot’s Bluetooth module (described here: Audio & BLE/SPP Pass-through Module Bluetooth 5.0 Wiki - DFRobot) so I can get my wiring diagram set up. DFRobot’s library on GitHub seems woefully out of date… Any help would be appreciated.
This part should do what you want. Before ordering boards print the pcb footprint out at 1:1 scale and compare it to a real part. Also the mounting holes are not drilled by default. If you want the mounting holes you need to drag a hole in to the sketch and place it over the hole in silkscreen.
