Hello everyone I have ordered my first PCB and it just came in, Im really happy with my first PCB but there are a couple things I want to change. The First thing is the screw terminals I used are completely the wrong silkscreen footprint but the pin spacing is right for the large I cant remember if the small pin spacing fit but I can check when I get home. Would anyone make me replacement terminals, I need a 3 pin for the 5.08mm(Large) and 2 and 4 pins for the 3.5mm(small)
Here is the datasheet for the large screw terminal:
Also I got this Mini Dc-Dc converter and I used the Mini-360 DC-DC Buck converter part posted in the past by Vanepp but its the wrong size, the one I need is 22mm x 17mm. will this other part posted work? im not sure about the pin hole spacing
DcDC converter I planning on using: SBX DSUN.fzpz (18.6 KB)
Mini DcDc converter picture/link from the amazon posting I cant find a datasheet:
Note that Fritzing 0.9.10 includes the voltage regulator parts that I did design. Rather than using a module you can just add a switching regulator to your board directly. It’s slightly more work than a module, but also much more elegant to have everything on a single PCB.
Yes that part should work (print out the pcb view at 1:1 scale and compare it to a real part to make sure though!) as it is 22*17mm which the mini is not.
Here is the 5.08mm 3 terminal part. If you do delete minus on the part currently in the sketch that will delete the part but leave the wires. Then you can drag in the new part and move the wire to (in each view) to reconnect to the terminals.
who makes the 3.5mm part? It doesn’t seem to be the OST part (the layout is different?) It is desirable to have a web page where the specs for the specific part are available included in the part.
Hello everyone i forgot that i needed a 3 pin terminal as well is there any chance you could make me a fixed up 3.5mm 3 pin screw terminal.
this is also from X2 Robotics.
