Im looking for a download for an esp32 wroom. similar to the one in the image below. it might already exist but when i search up esp32 i cant seem to find it
I have such a fragment, but it still needs to be completed. It definitely has errors in the schematic and the PCB view. I can no longer say where I got this part from. But I would try to finish it.
This is what the unfinished part looks like; is this what you mean?
ESP32 Dev_Kit .fzpz (27,2 KB)
Regards, Harald!
thank you very much!
I just received a similar request. I think they are also looking for this part. I will work on it, but it will take a bit of time. The SVG file needs to be edited.
Here’s the image of the ESP32, do you mean this one?
Regards, Harald!
I’ll link you to the topic.
I think it’s about the same component? Then we can save ourselves some work.
Regards, Harald!
Hi harold, it looks like this is the same as the one I need. i have to make sure with the pin setup but it looks the same.
Thank you, Stamatios
I have uploaded my results here:
Forum post: “Does anyone has the file for 3,2” LCD 320x240 ILI9341?"
The files can also be modified, improved, and reinserted.
Regards, Harald!
