I want AMG8833 IR 8x8 Thermal Imager Array Temperature Sensor Module for my Circuit
The Above is the link for the component
Pls Send me the Components as an FZPZ file as soon as Possible
Thank you
Thank you
This should do what you want. As usual if you want mounting holes you need to drag a hole in to the sketch as the mounting holes are only in silkscreen (no hole will be drilled by default.)
amg8833.fzpz (5.0 KB)
