This should do what you want. Since I don’t have one, and thus did this from the data sheet you should print out the footprint at 1:1 scale and check both the pin positioning, hole sizes and the pin numbering match the real part before ordering boards. As well the slots for the mounting tabs are implemented by two 0.8mm holes, so it may be necessary to cut or file the slot wider (Fritzing and I understand most of the cheap board houses don’t do slots.)
Thank you very much! I will give it a shot. It will take some days to report back, if everything worked out. Don’t worry about the slots, I drill all my holen in 0.8 on my cnc and then widen the necessary ones with a drillpress by hand.
