Hello.
Is there anyone here who has the part construction tooling set-up and working and is interested in creating (open-sourced) designs on a (modestly) paid basis?
Thanks,
Jerry.
Hello.
Thanks,
Jerry.
Request the parts you want in parts help and likely one of us will make them.
Hello again!
I will establish the pinning.
Same data sheet as the first one. There isn’t a pcb version of the mono jack and as noted no apparent link from the “schematic” to the numbered pins on the pcb footprint. The data sheet is here:
The manufacturer of the Cliff part(s) will be contacted.
For the sake of argument, consider using these as a prototype for a new parts library entry: https://docs.rs-online.com/a26a/A700000007116311.pdf
This part should do what you want. Although likely only for this particular socket as the footprint is slightly different than the first one. It would also be a good bet to print the pcb footprint out at 1:1 scale and compare it to a real part as I don’t have one.
Replaced part with one that has a label of J instead of A.
rs-pro-175-0155.fzpz (5.6 KB)
Hello Peter,
That is super. Thank you. Let me have a look later today.
Please let me know a Paypal/Patreon/Payment platform address and I’ll settle that. If you have a charge scale in mind let me know.
Thanks again
Jerry
