Looking for a CanaKit breakout board part
CanaKit Raspberry Pi GPIO Breakout Board
Previous work, similar parts
Similar to the Adafruit T Cobbler Plus Assembled Pi T-Cobbler Plus - GPIO Breakout [Pi A+, B+, Pi 2/3/4, Zero] : ID 2028 : Adafruit Industries, Unique & fun DIY electronics and kits
[x ] Breakout board, sub assembly, plug in module (A)
While a part could be done it isn’t worth the effort. There is no dimension information and no indication where the connections to the 3.3V and 5V (presumably the RPI pins) go. But mostly the existing adafruit part does 99% of that this does and the extras aren’t worth the work involved.
Thanks for looking at this…
I’m also looking for this part as well, I couldn’t find any more information for it than is provided in the image. There is a SparkFun one but it doesn’t have the power rails.
I have something similar, but it looks a bit different. Maybe you can use it.
Adafruit T-Cobbler.fzpz (47.1 KB)
Regards, Harald!
Already have that one and the Spark fun one, but thanks. I’ve been looking one that has at least the power rails if not the Canakit one specifically.
