Looking for 9000W N-/P-MOSFET/IGBT to switch 200V @ 450A
if possible with hole to attach a Heatsink.
A data sheet for the part you want would be required to determine if an existing part will do what you want.
sorry I actually meant:
90kW P-IGBT to switch 300V @ 600A
but here´s the data sheet:
configuration:
Individually
Collector-emitter blocking voltage U(CES):
600V
collector current I(C):
300A
I(CM):
400A
VCE saturation (max):
5 v
Power (max) P(TOT):
90000W
input type:
default
package:
TO-247AD
Switch-on delay time t(d)(on):
19 ns
Switch-off delay time t(d)(off)(2):
60ns
collector residual current I(CES):
300uA
input capacitance:
1960pF
Q(G):
77 AD
series:
GenX3
execution:
pt
mounting type:
through hole
Product Type:
IGBT
-50°C - 180°C
Still not sufficient information. I would need a part number (to know what to call it), the pin out and schematic diagram and the footprint of the TO-247AD package to make a part. A google search for “90kW P-IGBT to switch 300V @ 600A” doesn’t turn up anything useful.
This part should do what you want. As always print the pcb footprint out at 1:1 scale and compare it to a real part (the hole size is set to 0.06in for the pins, the data sheet didn’t have a hole size so it is a guess!)
GSI_VX_0544-a.fzpz (4.7 KB)
