2.8inch HDMI IPS LCD Display (H), 480×640, Adjustable Brightness, Optical Bonding Screen
Previous work, similar parts
Comment: the link contains screen display with pins. but the board that I want seems to have only HDMI and type c ports with no pins. If you can make them clear in the design (I mean the HDMI and type c port, I would be thankful).
