I cant open module part in fritzing
It says there is already a part with id ‘KY-013…’ loaded into Fritzing.
Its my first time using fritzing
What should i do?
I have to put 4 parts in my fritzing.
Help mee!
What should i do?
Help mee!
The error message indicates you already have a KK-013 part in your mine parts bin like this:
so you can either drag the part from the mine parts bin in to the sketch, or right click on the part and select delete part (you then need to shut down Fritzing and save the parts on shutdown to complete the deletion.) Then you can load a new version of the part if that is what you want to do.
