First time using fritzing and I’m trying to draw my first ever schematic. I’ve added an LM7805 positive voltage regulator, but I also need an LM7905 negative voltage regulator. Where do I find this?
KLTM
KLTM
The idea (which isn’t perfect, as you can’t change the voltage) is to change the part number in Inspector. I believe the pin out should be the same as the 7805 (if not you will need a custom part!)
If you change the part number in Inspector (the lower right window) it will change the label (it can also change it in the part, but this part doesn’t appear to be configured that way!)
