I’m trying to use the standard LM386 component from the library.
When I connect to pins 1 and 8 to a pot or PCB headers in the Schematic view, there is always a ratsnest directly between them in the breadboard view.
Is this a bug, or some sort of “feature”?
There is an error in the part (a bus between pins 1 and 8 when there should not be.) This corrected part should fix that.
LM386-fixed.fzpz (5.9 KB)
