LM2596HV-based AC/DC to DC Buck Step Down Converter Module
Previous work, similar parts
There is an old part based on the LM2596 (not LM2596HV): fritzing/LM2596 step down module.fzpz at main · jamesgilbs/fritzing · GitHub
From 3D model:
From actual photo:
Bottom View
I don’t think there is an official datasheet, but a lot of information can be found in the product description here.
The only data sheets I can find are for the LM2596HV component, but not the entire module: https://hmsemi.com/downfile/LM2596HV.PDF
length: 51.30mm
width: 26mm
This part should do what you want. Note pcb view has been suppressed as not useful (the input and output are via screw terminals.)
lm2596hv-buck-converter-module.fzpz (9.7 KB)
Thank you so much, that works perfectly for me! :slight_smile:
