LM2596 Solar Charging Module Dual USB DC-DC 9V 12V 24V 36V to 5V 3A
Input: 6V-40V (DC5.5/2.1 port, terminal connection)
Output: 5V/3A (MAX) (Apple anti-recognition)
Efficiency: 92% (MAX)
Conversion frequency: 150KHZ
Working temperature: -40 ° - + 85 °
Load capacity: Maximum output 3A (Connect to two phones at the same time)
Scope: mobile power supply, mobile phone, USB5V flat screen support device
Product size: approx. 50 * 35 * 12mm / 1.96 * 1.37 * 0.47 ‘’
Net weight: approx. 17g
Not enough information here to do anything with. We would need a web site that gives the physical dimensions of the part and the connectors. While I could waste time searching the web, I don’t choose to. This is why there is a template that requests this data in this category.
