LM2596 Buck Convertor.fzpz (17.3 KB)
There already is such a part in core parts so you are reinventing the wheel. That said schematic is slightly mis scaled so it doesn’t align to the grid.
This isn’t reinventing the wheel. The part in core parts is not the same size as the commonly available module. I discovered this today to my cost when I tried to fit a “LM2596 DC-DC HW411” module to my new board - and it didn’t. However, the part put forward by Learnayg is the correct size. Thank you.
There is just one problem with this part. If you place it, totally on its own, on a PCB, it generates a DRC fault located on the negative input connector. It turns out there is a rogue “path19” in the PCB SVG on top of the offending location. After I removed that and re-loaded the svg in the parts editor, the DRC check passes.
