LJC18A3-B-Z/BY Capacitive Proximity Sensor
I need the Capacitive Proximity Sensor model LJC18A3-B-Z/BY.
Looks to be identical to the one I posted. I can’t find a pin out to see if the colors match though (I expect they will.) so the same part should do for both. This is good because I appear to have strained my wrist and can barely type (and likely not make parts for a while at all!)
OK I found the pinout (which indeed is the same) here
in the last image and converted the original part to this
ljc18a3-b-zby.fzpz (4.9 KB)
Thank you so much. You are right also. It is same with other.
