Linear Actuator 12V
Hi there !
I´m trying to find this type of linear actuator part, but I can´t find it, can someone help me?
Thanks!
Linear_Actuator_12V.PNG|534x500
Not exactly what you want but maybe close enough.
Thanks for the fast respond.
I have already found this part, still i hoped that someone would have the other actuator.
I’ll wait, maybe someone will reports.
There isn’t any other linear actuator fritzing part that I am aware of (that is why I made that one.) The image is insufficient to make a part (no indication of what the connectors are for one, no size information) I would need the web page or data sheet for the unit to make a part.
edit a google search found the data sheet so here is a part.
linear-actuator-Actuonix-l12.fzpz (5.4 KB)
Hi Peter,
Thanks a lot for this.
That was a great help to me.
Best wishes!
I’m looking for this type of linear actuator part, could you hep me,please?
Thanks for your attention.
First a picture is essentially useless as it contains neither dimension or connection information. The actuonics web site here is needed:
https://www.actuonix.com/l16-50-63-12-p
specifically the data sheet page here
https://actuonix-com.3dcartstores.com/assets/images/datasheets/ActuonixL16Datasheet.pdf
then an appropriate part is available here in the forum (which a search for linear actuator or a google search of the form “fritzing part linear actuator” will find.
Thanks for your reply. I’m trying to find Actuonix L16-100-35-12-P linear actuator fritzing parts, but I don’t.
The part “linear-actuator+pot.fzpz” in the post referenced above will work for this particular actuator. The connections are the same (it was made on an L12 unit.) In general you need to use what is available as making parts for each specific model is impractical.
