How can i get Library for the TP5100 battery charging and protection module? If someone has pls share it .
There wasn’t one, but I made a TP5000 for someone several years ago so it wasn’t a hard part to make. Note pcb is made from a jpg image so if you want to put this on a pcb print out the pcb footprint at 1:1 scale and compare it to a real part as it likely isn’t exact at the moment.
tp5100.fzpz (8.8 KB)
