Can you help me to get (Li-ion 18650 Battery Charger Board with DC-DC Step Up Boost Module TP4056)
( 1pcs Tp4056 Tc4056 Type-c/micro/mini Usb 5v 1a 18650 Lithium Battery Charger Module Charging Board Dual Functions Li-ion - Integrated Circuits - AliExpress)
The part here (found by a google search of the form “fritzing part TC4056 Type-c/Micro/Mini USB 5V 1A” should do what you want.
Thank you for help me, but can you tell me about this (5PCS 5V Boost Step Up Power Module Lithium LiPo Battery Charging Protection Board LED Display USB For DIY Charger 134N3P Program) please
5PCS 5V Boost Step Up Power Module Lithium LiPo Battery Charging Protection Board LED Display USB For DIY Charger 134N3P Program - AliExpress thanks in advanced
No. There is no connection information for this that I can see which would be required to make a part for it. You would be better to use the part that already has a Fritzing part I expect.
