FritzingCheckPart has a few complaints about the uploaded part, but they are minor. Nothing that should cause the problem you saw. The part you uploaded is also in the core library. With your part for reference, I found the core part by searching for “graphic lcd”. Testing with that, I did not have any problem connecting separate wires to pin 15 (CS1) then pin 14 (DB7). From that, I suspect you encountered one of the Fritzing issues with corruption of the internal connection information. The real cause of that has not been tracked down, but seems to be triggered by creating, editing, deleting wires (connections) in multiple views. The recommendation, is to do all of the wiring in a single view, then create the wires in other views only from the ratsnest lines. That seems to avoid the problem. The usual fix when the problem occurs, is to pick one view as the reference, delete all of the connections in other views, then recreate the wires from the ratsnest lines. The wires in a view can be easily deleted by using “Select all traces” in the Routing menu, then press the delete key.
That is just a guess from what I have seen on the forum. If you still have the full sketch file (document) that shows the problem, you could upload that for us to have a look at. Since the alternate part I referenced seems to be better for your case, you may not care any more.
von Google Translate
FritzingCheckPart hat einige Beschwerden über den hochgeladenen Teil, die jedoch geringfügig sind. Nichts, was das Problem verursachen könnte, das Sie gesehen haben. Der von Ihnen hochgeladene Teil befindet sich ebenfalls in der Kernbibliothek. Mit Ihrem Teil als Referenz fand ich den Kernteil, indem ich nach “Grafik-LCD” suchte. Beim Testen hatte ich kein Problem damit, separate Drähte an Pin 15 (CS1) und dann an Pin 14 (DB7) anzuschließen. Ich vermute, dass Sie auf eines der Fritzing-Probleme mit der Beschädigung der internen Verbindungsinformationen gestoßen sind. Die eigentliche Ursache dafür wurde nicht aufgespürt, sondern scheint durch das Erstellen, Bearbeiten und Löschen von Drähten (Verbindungen) in mehreren Ansichten ausgelöst zu werden. Die Empfehlung besteht darin, die gesamte Verkabelung in einer einzigen Ansicht durchzuführen und die Drähte in anderen Ansichten nur aus den Rattennest-Linien zu erstellen. Das scheint das Problem zu vermeiden. Die übliche Lösung, wenn das Problem auftritt, besteht darin, eine Ansicht als Referenz auszuwählen, alle Verbindungen in anderen Ansichten zu löschen und dann die Drähte aus den Rattennest-Linien neu zu erstellen. Die Drähte in einer Ansicht können einfach gelöscht werden, indem Sie im Menü Routing die Option “Alle Spuren auswählen” verwenden und dann die Entf-Taste drücken.
Das ist nur eine Vermutung von dem, was ich im Forum gesehen habe. Wenn Sie immer noch die vollständige Skizzendatei (Dokument) mit dem Problem haben, können Sie diese hochladen, damit wir sie uns ansehen können. Da der alternative Teil, auf den ich verwiesen habe, für Ihren Fall besser zu sein scheint, ist es Ihnen vielleicht egal.
