I am looking for a part for my LED’s, it is a 2835 size white LED.
Currently I have found two capacitors that have the size 3528, can someone tell me if they are compatible?
Thanks for an Info.
Olaf
Thanks for an Info.
Olaf
This should do what you want. As always before ordering boards print the pcb footprint out at 1:1 scale and compare it to a real part. Also check the polarity, I think it is correct but it may not be.
67-21s_kk5c-h402633z6_2t_smd_led.fzpz (4.5 KB)
