Is there anyone who could help a beginner to get a part definition for a panel-mount, 2-lead momentary push button switch? It’s a Keenso motorcycle accessory switch and I got it from Amazon. I think it’s supposed to be terminated by soldering to wires but I want to solder it to a PCB instead. No P/N or data sheet is available but they do offer these pretty pictures:
I checked the PCBway webside and these dimensions for the holes and pads should work:
There is an existing switch in the ‘Contributed Parts’ bin called ‘Round Pushbutton’ that could probably be copied - just the hole and pad dimension need to be changed.
I don’t need any fancy images, I just need to find a way to get the correct holes and pads on my PCB.
