I didn’t find anywhere and I need it ![]()
Can you give a picture/link of the product… 1.5mm is pin spacing… & how many pin you want…?
You can also use normal header pins, and set it to 1.5mm pitch, and choose the hole diameter & ring thickness…
I was trying to do your advice but in your image it seems that you have other sizes for the header’s hole but in my program it doesn’t appears other sizes, the minimum is 0.7
and I cant change it.
Change it by typing the value… Don’t use dropdown option…
