Has anyone had an issue with the soldermask layer showing up incorrectly in the Aisler.net PCB view?
The top layer is fine, but there are quite a few issues with the bottom layer where solder mask is in the incorrect spot, in some places covering the solder pins of smd IC’s.
I’ve imported the gerber file into other fab house software for rendering, and the issue doesn’t exist there, so i can’t see how it would be an issue with my design.
This is the 2nd 2-layer board I’ve designed, the first one had no issues from Aisler, i feel like a bug has crept in.
