Hey everyone! I need some help finding the fritzing file for a relay module with an ir receiver included.
It looks like this:
Thanks!
It looks like this:
Thanks!
I expect there isn’t a part. A google search for "relay module with an ir receiver " followed by a look at the images doesn’t turn up this particular module so we would need a web site for the module to make a part.
Peter, I was hoping someone here could help me with this module. I was given it at school in order to make it work in a project, but I’m having such a hard time finding code that works with it and now finding the fritzing file to make the blueprint/map (sorry, english is not my first language). I’ve found some websites that sell this kind of module with the remote control included, but there´s no information available about it (only that it works with 12V, and the model: IR05). Maybe something in this paragraph helps you find something, I really hope it does.
Anyways, thanks for answering my previous question and trying to help me!
Emilia ![]()
OK, I think I have enough information to make you a part for this. On this site
there is this image
and dimensions for the board which is enough to make a part. I’m assuming that 12V DC comes in on the 2 pin header and drives both the IR receiver and the relay. Then the IR receiver switches the relay on or off and causes the relay to switch. I should have a part for this fairly soon as I have a similar (without the IR receiver) module already.
OK this part should do what you want.
ir05-IR-controlled-relay.fzpz (11.8 KB)
It doesn’t need any drivers, just 12V on the power leads and then the IR remote will turn the relay on and off.
Thanks so much Peter! You’ve been really helpful!
