Created the HERO board if you need it
HERO.fzpz (53.5 KB)
I was surprised “hero” was not in the part name when I searched for it from my parts catalog.
It appears to be a partial part at best. It looks like only the arduino pins are actually defined, and then only the ones on the header (the circles just up from the header should also be bused to the header but are not defined as connectors in Fritzing nor are the 12 pads beside the icsp connector. Pcb appears to be a Uno (which may be fine.) The internal buses are messed up which likely means the connectors that should be bused together are not. So I would use this part with caution as it is no where near complete.
