Introduction to fritzing + tutorial (by Raptor7762)
(edit from post above)
Breadboard View add-in
You can add text to your sketch in breadboard view. Just:
You can change the colour of (the) wire(s) too. Just right click on the wire > wire colour, then select your desired colour.
Schematic View add-in
Just like the breadboard view, you can add text too.
Steps are similar, except that this time, drag the part from the core bin > schematic view
(continued from post above)
PCB View
When you open up the PCB view, you will see something like this:
You will notice that there is a huge rectangle in the middle. This is your resizable PCB. You will be putting all your components in this PCB. Such an example would be:
You will also realize that there are new tools in the parts palette for pcb:
Don’t worry if you do not know how to use any of these parts. I’ll be covering the purposes of these parts.
1. Rectangular PCB - Resizable
This part is basically a PCB board. You can resize it to your desired dimensions by clicking on the part, then left click + drag ⌜,⌝, ⌞or⌟ to resize the Rextangular PCB part. You can also key in the desired width and height in the inspector like this:
One reason why I don’t really like the interface is that the units are in mm.
If you are not used to mm (like me because I prefer the grids set to 0.1 inch), then convert the inch to mm.
Google is your best friend. Just search “inch to mm”, copy and paste the mm values into the inspector, and… Done!
2. Jumper
The jumper part allows you to place a real wire between two connectors.
3. Silkscreen Text
This part allows you to add text to your PCB.
Just drag the part and place it on the Rectangular PCB, then with the Silkscreen text part selected, go to inspector > properties > text and change “logo” to your desired text.
4. Silkscreen Image
This part allows you to add a silkscreen image
Just drag the part and place it on the Rectangular PCB. If you want to change the image, select it, go to inspector > properties and select an image from the dropdown menu, and change it to your desired image. You can also load your own image file. If you do, you should look at this post
5. Hole
This part allows you to have holes in your board.
Just drag the part and place it on the Rectangular PCB. If you want to change the size of the hole, go to inspector > properties > hole size and select from the dropdown menu your desired size. If your desired size is not available, then key in the hole diameter and ring thickness in the advanced settings.
6. Via
This part allows a junction between a wire from the bottom layer (coloured in orange) and a wire from the top layer (coloured in yellow). Here is one such example:
The next few parts are my “never ever used” parts, so to be honest I have no idea how to use them. I will edit this post again once I find out more information, so I’ll skip them first.
Things that you need to know
There are a few important things you need to know for the PCB view.
  1. Moving wires to different layers. Just right click on the wire > move to bottom/top layer.
  2. View from ____. You may need to know how to view the PCB from different perspectives. Just press “view from above/below”
For all views
1. Adding Notes
Creating a note can only be done when you are only in breadboard/schematic/PCB view.
The ways of creating a note are stated in this topic.
  1. Go to edit > add note
  2. Press the “Add a note” button in the red section on the bottom of the app
  1. Drag the note part from the core parts
