Installation errors
Installing Fritzing - Error Messages: Can somebody assist me with the following error message when attempting installation with Microsoft Windows 10 Pro on Desktop HP ZBook 15 G2:
  1. Called RunScript when not marked in progress.
  2. Called InstallFinalize when no install in progress.
  3. Fritzing setup ended prematurely because of an error. Your system has not been modified. To install this program at a later time, please run the installation again.
Tried a few times with no luck.
Try running the installer with the debug log enabled and then open an issue on github. The command to enable the log file follows the link. I have never had to use this because I have never had a problem installing on Win10, but I did note the command to get a log file in case I ever needed it.
msiexec /i “C:\MyPackage\Example.msi” /L*V “C:\log\example.log”
