Hi,i need this component. Somebody have it? ifx007t
Tnx
Thank a lot Peter.
Do you have also 74hc244?
I NOT need on smd format
There doesn’t appear to be one (a google search for “fritzing part 74hc244” doesn’t turn one up.) You can make on from the generic IC by changing the pin labels of a 20 pin DIP part (or an SMD part if you need that.)
Hi, do you know if this exist not for SMD welding but with standard case?
Thanks
The default case is DIP not SMD.
