Although the inspector for every resistor has a “power” category, they are all inactive. I need to place eight 2W THT resistors on a board (they have values like 5.6 ohms, 11 ohms, and the highest one is 18 ohms, the lowest 4.7 ohms). To simplify construction, I will be using the Adafruit Perma-Proto full-size board so the student can construct the final version directly from the breadboard layout.
Type in whatever you want in the power box, and same for ohms.
It won’t change the resistor diameter in PCB view, but you can change the length.
