I’m looking for Fritzing Part for B503 Potentiometer. I have searched on Google but I still can’t found it
Not enough information here to make a part. What is the pin out? Like this (dual resistor elements) or a single resistor element and a switch? What parts connect to what pins?
I found its datasheet here. Since I’m a new member, I can’t upload many pictures
It’s dual resistor elements
This should do what you want. As always, before ordering boards print the footprint out at 1:1 scale and compare it to a real part. The slots have been replaced by two 1.2mm holes (Fritzing doesn’t do slots easily.) The pin numbers will be wrong if you have the taper type pot (I assumed the standard one)
b503-pot.fzpz (12.5 KB)
