can anyone help me? I need a hand or if anyone can create me the gerber file of this circuit with these specifications: radius 70mm. 50Watt 12-14Volt using 1-3-5Watt smd leds, I don’t know if resistors are needed.
First item of business would be a Fritzing part for what ever LED you are using. If there currently isn’t one, a data sheet for the LED would be required to make one. After that we can probably provide you with instructions to make a sketch.
I hope these go well, the only thing I don’t understand is why on the PCB it has two pins and on the schematic it has three
You would need to upload the ,fzpz file for the part you are referring to (upload is the 7th icon from the left in the reply menu), that said there are three pins in the pcb images you uploaded:
although I have no idea what the third pin is for, it appears to be an SMD led and the third pad may be a ground or for heat dissipation (it is unclear from the image or schemtaic) the data sheet for the LED may tell you.
