OK, I’ll be submitting another enhancement request for that.
Just completed doing that:
The modified schematic symbol contributed by Peter
part.resistor-iecschematic_1.fzp
https://forum.fritzing.org/uploads/short-url/7r98HeqKNwKSUdOSlBUyWHiHGqw.fzpz
@KjellM replied:
One workaround could be to use the part number to display the resistance:
The part number is also exported to the BOM, both html and csv version.
Of course this introduces the problem that part number and resistance might be out of sync.It think the technical reasons to use the RKM notation (IEC 60062 2016) is a bit outdated.
Main points mentioned in the standard: Avoid errors from missing dots, and fixed length encoding for database.
I think neither is an issue since decades.
Just writing down the value with its physical unit seems to make more sense.
Especially for beginners, physical notation probably should be the default. You can learn RKM notation anytime, but why first time you see a circuit?There are still valid use cases:
- On PCBs, the silkscreen may be quite coarse, and RKM is more robust and compact.
- Popular export formats for pick and place and PCB testing use fixed length encodings.
As I understood it, the standard suggests using capital letters corresponding to the SI prefixes (2K7, not 2k7). I think the later is still used quite often.
If we implement a setting, like switching a project to IEC, there might also be a setting to switch to RKM.
Which RKM notation? I’d guess 4 digits + tolerances?
How should I reply?
